RUI Studio Help
Variable design
Names, types, VP, arrays, and initial values for the device; stored in .uiproj.
Open Variable design from the menu or toolbar. Define C types, array sizes, and initial values for the panel and the host protocol. OK writes .uiproj for control bindings and Export code.
Columns you change
ColumnRole
NameWhat bindings show. After a rename the app rebinds by name — still open each control
VPWire address (read-only). Bindable scalars from 1; nameless or arrays show
TypeI32, bool, float, string, string table, and so on
Dim 1 / 2Array or string buffer. For strings, dim 2 is capacity
Min / maxRange for sliders and progress bars
Integer / decimal digitsHow associated soft/embedded text shows numbers
RemarkFor you
Initialization under the table is the current row’s default. Multi-character text via the English keypad maps to UI_VAR_STR (about 63 characters + NUL).
Buttons
Add / Delete / Up / Down / Auto arrange change order. Order drives VP and dropdown index — check bindings after a shuffle.
Generate dwin_var.h is for the product host, not the panel. The panel uses UI_VAR_* from UIMap. See HMI UART.
Touch areas, sliders, switches, and labels bind this table by dropdown index. Digit width and prefixes travel with refresh associations. The main window also has a read-only Variable table tab; double-click opens this window.
Overview: Variables and callbacks.
