Table conditional format
Threshold colors, disconnect N/A, jump detection; DEL must not delete the table.
Property group Conditional format. Where numbers come from: Table data. Overview: Table.
Overlay order (first match wins):
- Disconnect (disconnect text, default
N/A) - Alarm (outside high/low limits)
- Jump warning
- Threshold warning (still inside alarm limits, outside the warning band)
- Whole-row fill when “Highlight row on alarm” is on
- The cell’s own fill
- Zebra
When on, one cell in alarm/warning tints the whole row. The panel has two palettes: warning (yellowish) and alarm (pinkish), each with a row block and a cell block.
Threshold rules
Set a numeric band on a column or cell:
- Double-click a body cell, or right-click Set condition rule.
- Or Add / Edit / Delete in the rule list.
Example: column 4 is normal in [210, 230], warning band 215–225. Outside the limits = alarm color; inside the limits but outside the warning band = warning color.
Note: with focus on the rule list, DEL deletes a rule, not the table. Click the canvas first if you mean to delete the table.
Disconnect display
When the link is down, cells do not keep stale numbers:
- Disconnect text, default
N/A. - Table-level online bool: one switch for the whole table (0 = disconnected).
- Row online array: per row (0 = that row disconnected).
- Preview disconnect look: see it on the canvas first.
Jump detection
Mark a warning when a value jumps too hard vs the previous frame:
- Enable Jump detection.
- Relative deadband % (default 5%) or absolute deadband — either one counts as a jump.
- Consecutive hits: require several frames over the limit to ignore noise.
- Show direction prefix: ↑↓ on the canvas;
^/vin export. - Preview jump look: simulate on the canvas.
If this is off, do not expect jump prefixes on the panel.
