Table data
Column arrays, enum mapping, cell scalars, paging, clickable keypad.
Property group Data. Fonts and look: Table look and fonts. Overview: Table.
Pick one data source — do not mix them:
| Source | Role | Paging |
| Bind column arrays | Each column binds a 1-D array; each page shows a slice | Yes |
| Enum mapping | string_table items; each cell picks an item mapped to a scalar | No (preview page ignored) |
Bind column arrays
- Set the source to Bind column arrays.
- Optionally Show sequence column (column 0): automatic
1,2,3…, no array. - Header titles: bind a string table (row i is column i, including the sequence column) or custom multi-line text.
- For column 1, column 2… pick a numeric 1-D array variable.
- Preview page
current/total: which page the canvas shows. Total pages = ceil(longest array length ÷ body rows), at least 1.
Rows per page = table body rows. Page p, row r maps to index p × rows + r.
Display format is currently raw values only.
Cell scalar variable
Bind a scalar on a body cell to override that cell’s column array / sequence. Paging does not change it. Headers cannot bind.
When click-preview is on, a scalar cell shows an amber S. Choose “None” to go back to the array or sequence.
If multi-selected cells disagree, the UI shows “(selection differs)”.
Enum mapping
- Switch the source to Enum mapping. Column arrays, sequence column, preview page, and cell-scalar rows hide.
- Pick the enum source (a project string_table; one line per item).
- Fill the table-level mapping: which scalar each item uses.
- Select a body cell and pick the enum item. Headers cannot pick an item.
The canvas shows a teal E badge. Runtime shows the mapped scalar and does not move with a paging window.
Clickable cells and keypad
Enable cell property Clickable:
- Effect demo / firmware: the cell darkens on press and restores lines and text on release.
- This does not run a callback on the cell. Use a nearby button or touch area.
- If the cell has a cell scalar and the table keypad kind is numeric: press opens the numeric keypad; OK writes the scalar. Place a keypad on the same page. Clicking a cell on the design canvas only selects it — it does not open the pad.
You can also Allow switching keypad kind. Changing page closes the keypad.
Merged slave cells do not export a hit area.
