Table
Place a table, pager buttons, and the four property groups.
Toolbar Table. With the table selected, the right-hand properties split into four groups that match these articles:
| Property group | What it covers |
| Look and fonts | Rows, columns, borders, zebra, merge; soft/embedded fonts, alignment, prefixes |
| Data | Column arrays, enum mapping, cell scalars, paging, clickable cells and keypad |
| Conditional format | Threshold colors, disconnect N/A, jump detection |
Three table-wide switches sit at the top:
- Lock: prevent accidental dragging.
- Use as container: dragging the table also moves overlapping elements above it (the pager trio already follows the table — do not treat those buttons as extra children).
- Show navigation buttons: prev / page number / next. Turn off to keep the grid only.
The status bar shows the current cell, for example “Row 2, column 5.” Font, data, and conditions apply to that selection (Ctrl / Shift multi-select).
Pager trio
With navigation on, prev, page label, and next appear below the table. They are companion push buttons; skins come from the button/ style pack.
- Drag the whole table: the pager strip and the three buttons move with it.
- Drag one button alone: only that button moves.
- The center label shows
current/totaland matches the preview page under Data.
In effect demo, click prev/next to change page. For jumps or writing variables, use a nearby button or a touch area. Do not expect callback code on a cell.
Format painter
The roller icon in the toolbar Format group. It copies one cell’s format onto others so you do not restyle each cell.
> [Figure] Format painter on the toolbar; source cell and dragged targets.
How to paint
- Select the source cell (the template).
- Click Format painter so the brush locks on.
- Drag (or click) target cells: font, border, fill, alignment, prefixes, data binding, and condition rules copy over.
- Release to finish the pass. Click the brush again for another batch.
Clear next to it only drops the current cell’s local font so column/table defaults show. It does not undo a whole paint pass.
Multi-select still edits the selection in properties. The painter is “one source, then wipe over cells you pass.”
An amber S means a cell scalar. See Table data.
