RUI Studio Help
Effect demo
Tap, drag sliders, and jump pages on the PC — no board required.
Toolbar Effect demo opens a separate window with a snapshot of the current project.
  • Touch areas can jump pages, change simulated variables, and refresh soft/embedded text. A sector with an angle variable writes the polar angle while dragging; on-screen digits follow only if refresh associations are set — see sector touch and angle variable.
  • Sliders, switches, buttons, and keypads follow the designed logic.
  • Press-repeat uses the same timing as firmware.
  • Implementation code is simulated in a limited way (loops can be interrupted by touch).
Zoom in the demo window is view-only. It does not change the scale stored in the project.
