Nine-state button
Inactive / active / alarm × normal / pressed / disabled.
Toolbar Button. The nine skins come from the button/ style pack or images you assign.
Properties you change often
- Bind an I32 semantic variable (0 inactive, 1 active, 2 alarm) to pick which skin group shows.
- Short press runs “Call callback”. Long press can use a separate long-press callback. A short press does not automatically change the semantic variable.
- Refresh callback runs before the short-press callback so a login jump is not overwritten by a refresh.
- You can attach companion text. On press it sinks 1 pixel by default.
In effect demo, hold the button: you should see the pressed skin and the text sink.
